5040 Oil Pump Pressure
Yooper
07-15-2005 14:43:10
If someone could help, please, it would be appreciated. I have a 5040 with about 2700 hrs. on it, the other day went to start it and the oil pressure light stayed on. Shut it down right away and did a little checking. It appears that the pressure switch is okay, tested it with air pressure and an ohm meter, opened at about 7 psi. Getting a pressure gauge to hook in instead of the light. The service manual says that to change the oil pump, the entire oil sump must be removed which is a fairly big job. Looking at the diagrams, though, it almost looks like it should be possible to access the pump by only removing the cover on the very bottom of the oil sump(pan).
Does anyone have any experience with doing this, what to look for with the oil pump and suggestions on what I should do? Also, could there be other problems created from the low oil pressure operating before the light indicated a problem? Thanks for any help.
