WD lift
jack
07-13-1999 10:19:40
will a WD lift round bales of hay,if the pump is right.
Larry
07-23-1999 14:57:35
 Re: WD lift in reply to jack, 07-13-1999 10:19:40
I use my WD to move round bales all the time. I've moved bales up to about 1500lbs with a 3 prong bail spear attached to a 3pt hitch. The heaviest bales at 1500lbs would someimes lift the front end, but I have absolutely no ballast on the front end either. Standard 4x4 or 4x5 bales at 1250# or so are absolutely no problem.
edwin
07-17-1999 17:29:43
We use our wd45 to move standard size round bales. My forks are a homemade frame that attaches under engine to brackets mounted in frame holes. The only time it picks up front of tractor is if I'm not completely under the bale.
Aaron
07-13-1999 20:11:53
It will lift the front of the tractor, as it is much lighter than the bale. You need more tractor, time to buy a 190 or something.
