Allis C...fuel line
Mike from Ohio
07-12-2005 21:40:33
Hello everyone...
I have an Allis C 1948. The fuel line is leaking where it connects to the sediment bowl. I have tried tightening it, no luck...I looked at TSC for a new line any suggestions on how I can fix this one or where I can find a new one...thanks!
Steve in N.J.
07-19-2005 03:58:47
 Re: Allis C...fuel line in reply to Mike from Ohio, 07-12-2005 21:40:33
Mike,
We make new fuel line kits for the B/C/CA machines. Drop us a line if interested...
Steve@B&B
Dick L
07-13-2005 09:22:25
I buy brake line tubing and bend them up to fit.
Texas Denny
07-13-2005 07:02:55
TSC sells sediment bowls and some brass. You could replace the metal tube with rubber gas line from an auto parts store. With new brass and a rubber gas line, you might not need a new sediment bowl. It is probably the flare or compression fitting that is leaking - not the pipe thread that mates with the sediment bowl.
