WD45 TRANS CLUTCH
H HOUSER
07-10-2005 17:46:01
I HAVE A 55 WD45 THAT SEEMS TO SLIP IN SECOND GEAR WHEN IN A HARD PULL.THE TRACTOR WILL NOT SLIP IN FIRST I CHECKED THE CLEARANCE IN THE TRANS CLUTCH DISENGAGED IS 20 THOUSANDTHS.I SAW IN THE SHOP MANUAL THERE WAS A COUPLER THAT REPLACED THE CLUTH.I'M NOT USING THE PTO NOR DO I NEED THE HAND CLUTCH. WHERE CAN I GET A COUPLER.CAN YOU USE TWO PTO DRIVE GEARS BACK TO BACK THANKS
Texas Denny
07-10-2005 18:47:00
 Re: WD45 TRANS CLUTCH in reply to H HOUSER, 07-10-2005 17:46:01
H Houser, how did you determine that the slippage is in the hand clutch and not the foot clutch? When the foot clutch wears out, it slips more in the high gears than the low gears. It is common for a clutch to slip like crazy in 4th (high) and not slip in 1st. If your slippage is in the hand clutch, it can usually be adjusted so it will quit slipping. Often a slipping hand clutch will not have a noticeable snap when it is engaged. If you think it is the hand clutch, your shop manual should completely describe the adjustment. It is pretty simple to do. If it solves your problem, you are done. If it doesn't, I'd guess the foot clutch is worn out.
H HOUSER
07-11-2005 12:40:53
 Re: WD45 TRANS CLUTCH in reply to Texas Denny, 07-10-2005 18:47:00
the foot clutch is a brand new pulling clutch. I believe the friction discs are worn enough not to hold the power.The engine is not quite stock
Texas Denny
07-11-2005 20:01:38
 Re: WD45 TRANS CLUTCH in reply to H HOUSER, 07-11-2005 12:40:53
My comments are the same. Adjust the hand clutch. After proper adjustment, your problem should be solved.
Tony Z
07-11-2005 06:46:38
So Texas Denny,
Is the "noticable snap" on the hand clutch normal? As I am new to tractors, I was wondering if that was normal on my 53 WD45.
Tony Z
Texas Denny
07-11-2005 19:58:59
 Re: WD45 TRANS CLUTCH in reply to Tony Z, 07-11-2005 06:46:38
Yes, the snap is necessary. The snap happens when the clutch goes over center. If there is no snap, the clutch needs adjustment.
