WC Rearend Oil
Bud W
07-09-2005 15:58:42
Like most WC's both of mine leak oil through the axle seals and leak out the holes at the bottom of the final drives. Mine are driven maybe 5 miles a year so replacing the seals doesn't seem practical. What is the best rearend oil to use to minimize leakage and still protect the gears to some degree. Thanks
dej(JED)
07-11-2005 10:38:12
 Re: WC Rearend Oil in reply to Bud W, 07-09-2005 15:58:42
Let the oil out and pump it full of grease. That will lubricate and all but eliminate your leaks. It only takes a little bit of driving it to coat all gear faces. After a 20 foot drive top it off.
old
07-09-2005 18:41:04
If you can find it a stright 140 will slow it some and still do a good job other then in very cold weather
