The govenor should also control the rpm at different throttle settings when you are standing still. If by wide open, you mean 1500 rpm, the govenor may still be trying to work. Check all of the linkages to make sure they are free and there is no binding. There is a large spring attached to the linkage under the gas tank. It needs to be in place and with the proper tension. A govenor consists of flyweights inside a housing ahead of the distributor or magneto. As engine rpm increases, these fly weights swing out. The action pushes on a ring which pushes on a lever which closes the carburetor. A spring pulls on this same lever trying to open the carbuetor. The engine increases in rpm until the force of the flyweights equals the force of the spring. At that point, the engine will stabilze at an rpm. If the operator control is opened more, a greater force is placed on the spring which causes rpm to increase until the the fly weight force equals the new spring tension. If the tractor is put under load, rpm will drop momentarily until the spring force overhauls the flyweight force and opens the carburetor. When the carburetor opens rpm increases until the forces are equal again. If load is removed, the rpm will increase inceasing the flyweight force which will close the carburetor, reducing rpm and flyweight force until it again equals the spring force. If as soon as you take the engine off idle, the rpm increases to fast idle (1500), spring tension would seem to be too high or something is wrong with the linkage. But the govenor is trying to do its job. If the rpm goes well above 1500, the flyweights may be stuck or broken or something may be wrong with the linkage. It is not hard to remove the distributor and govenor as a unit to check the flyweights. Buy a IT manual at your local farm store. The pictures are invaluable.
