170 hydraulics
nancy
07-05-2005 20:01:51
on my 170 the arms will go up and down with attachments. But when nothings on it it will not go down. Any Ideas?
Farmer Gene (NW WI)
07-06-2005 02:16:24
 Re: 170 hydraulics in reply to nancy, 07-05-2005 20:01:51
On my 190"s you have to have the traction booster and depth control levers all the way back and then hold the hyd lever all the way foward.
Eldon (WA)
07-05-2005 20:35:11
Do you have the traction booster and depth control levers all the way forward?
nancy
07-06-2005 00:04:39
 Re: 170 hydraulics in reply to Eldon (WA) , 07-05-2005 20:35:11
Yes both levers are forward.
jrlii
08-15-2005 15:53:21
 Re: 170 hydraulics in reply to nancy, 07-06-2005 00:04:39
The lift cylinder is single acting: The hydraulics pick up the arms, but only gravity brings "em back down.
If I raise the lift arms too much while hitching an implement, I stand on the right arm and push the lever into the down position (it"s a bit of a streatch.)
Make sure the position control & traction boost levers are fully forward, so the boost pump doesn"t hold "em up.
You might also have to lube the position control and traction boost linkages: I had a heck of a time last winter trying to use the box blade after leaving my 170 out during an ice storm. The hydraulics seemed to have a mind of their own due to frozen linkage joints.
