D-17 Gas
Kim Hammer
07-05-2005 18:33:01
I have a D-17 gas that I can"t get to start. It needed a new muffler and since I put that on it won"t start. The tractor cranks over and I"m getting spark. When I let go of the key gas runs out of the carburetor. I have removed the muffler and the same thing happens. I have even rebuilt the carburetor. Any help would be appreciated. Thank you
Eldon (WA)
07-05-2005 20:44:18
 Re: D-17 Gas in reply to Kim Hammer, 07-05-2005 18:33:01
If you have spark and gas, put in new plugs and try shutting off the gas at the sediment bowl and start the tractor (may need a shot of ether, but usually there is enough gas to let it run for a minute or so). Then open up the valve and the vibration usually will take care of the problem. If it floods out, tear the carb down and soak it in some good carb cleaner overnight, blow out the orifices and put it back together and try it again. This procedure has worked many times for me.
Gatz
07-05-2005 19:54:53
gas running out of carb usually means the float is stuck, float is leaking, float not set to correct height, or the needle vavle seat is bad.
