Allis Chalmers 5015 voltage regulator
Lawrence Viller
07-05-2005 05:26:38
This tractor was given to me by my father. The voltage regulator has gone out and I am having trouble locating a replacement for it. Does anyone know where I could find a voltage regulator for this type of tractor? If not could someone tell me what the part number is so that I can have my local parts shop find one.
James Eggers
02-21-2006 12:15:26
 Re: Allis Chalmers 5015 voltage regulator in reply to Lawrence Villermin, 07-05-2005 05:26:38
If you still need one email me I found a place that has them for 165.00 if you found one cheaper or something else that will work please let me know.
Thanks
souNdguy
07-05-2005 11:18:40
If you com eup empty handed, post back.
I'll assume we are talking about a standard 2 brush genny...All you basically need to know is the voltage ( 6/12 etc.. ) and circuit type ( A circuit / B circuit ). If you can't find an OEM one.. I'll bet you can get one from another genny to make it kick over.
You can tell circuit type by looking at old VR. On the old vr on the bottom you will find a bias resistor. it may be hooked from Armature to field.. If so.. this is a B circuit type... Field is internally grounded, and needs power to charge. Initial charge current is from the residually magnetized field shoes feeding thru the bias resistor to the field. If the bias resistor is hooked from the ground frame to the field, it is Acircuit type... field is internally hot ( connected to armature), and needs ground to charge.. bias resistor provides some of that ground.... After charging starts.. cutout pulls in and the vibrating contacts start doing the regulatin'.
Soundguy
phil(va)
07-05-2005 09:43:08
I haven't a clue, but I would bet if you take your generator and old voltage regulator to a good automotive electrical shop that they can match it up.
