Dead distributor
Brian
07-11-1999 17:07:29
Anybody out there have any trouble with those electronic kits that replace points in the distributor? Mine failed today on the way home from the carwash. Just when I thought my tractor was liking me, new engine, new paint, bath, it left me to walk home. Brian
Mike
07-14-1999 15:58:44
 Re: dead distributor in reply to Brian, 07-11-1999 17:07:29
You sure the kit is dead? It might be that the electronics are fine but that when you started the rig and got it warm, the water from the carwash (the same water that got inside the distributor) evaporated from the bottom of the distributor housing (where the heat is) and condensed on the inside of the distributor cap (where it's just a little cooler) and esentially shorted out your ignition system.
If this is the case, try drying out the distributor by leaving off the cap or blowing it out with warm air (carefully).
One quick but not all inclusive check would be to disconnect the ignition coil secondary lead (the one that will knock you on your butt) from the distributor and place it near the frame of the vehicle so it can make a spark, then, WITHOUT HOLDING ONTO THE WIRE, crank the engine and see if there is in fact a spark. OR
You could take a samll test/continuity light and hook the ground lead to the frame of the tractor and hook the other end to the plus (+) side of the coil. With the ignition turned on you should have the light come on, if it doesn't, you have no power to the coil. If it does, then hook the test light across the coil leads (one to the plus and the other to the minus) and crank the engine. The light should flicker each time the plugs are supposed to fire (it may be very dim because the spark pulses are very short).
Remember that each time you crank the engine the coil "May" make a spark. You probably have heard of what happens to people who touch things that make sparks when those things don't want to be touched...
