roto baler
gary lee
07-01-2005 12:37:16
does anyone know how big of a bale you can make with a roto baler? the normal big round bales, 1000 pounds plus are way to big for my needs. the 50 pound small squares are way to small. wondered if you could make like a 250 pound bale with a roto baler.thanks, Gary
Hurst
07-02-2005 09:14:23
 Re: roto baler in reply to gary lee, 07-01-2005 12:37:16
Newholland makes a larger small square baler (not the huge ones, just a little larger than the small square balers). These bales have 3 strings instead of 2 and weight over a 100 lbs normally. The weight you want is going to be hard to find. maybe you can find a 4x4 ft variable chamber round baler and then make them 2 or 3 ft tall (don't even know if that is possible)? Good luck
Hurst
JMS/MN
07-01-2005 12:39:06
No. Tough to get them anywhere close to 100- more likely 50-60 lbs, depending on what you are baling.
