allis chalmers 190
tractor mecanic
06-30-2005 20:38:38
my father has a 190 gas allis. if you know any thing about power director. if we put the lever in back position it will spin tires!>some times!
the problem is when the lever goes forwars its like the tractor is in neutral and wont move!
>>>my father says main clutch wouldnt work one minute and not the next he thinks maybe valve? thank you!!!
Joe(TX)
07-02-2005 17:13:27
 Re: allis chalmers 190 in reply to tractor mecanic, 06-30-2005 20:38:38
Check the linkage between the shift valve and the lever. The bushings in the bellcrank are probably loose. The valve may not be fully shifting.
Kent of SW MO
07-01-2005 06:05:20
Dads 190 was something like this. It had fail not long after work had been done on the Power Director. Ue live with it for years until the tractor would not move out of a creek one day. We split the 190 and found that the center sealing ring had fail putting oil pressure on both the high and low clutch pack. We replaced the clutch packs, sealing rings and the housing the sealing rings seal in. Works great now.
Kent
Jerry from East Iowa
07-01-2005 04:57:58
Hi If I was to guess, I would say it is in your power-director.Losing pressure by the piston or your clutch pak slipping. Could be in your valve, but it has been my experience that it will be inside.Fairly easy fix, not horribly expensive.You have to split it behind the torque-tube,then everything is right in front of you.If you have questions please feel free to write or [email protected]
Thanks,
:) Jerry
Jerry's Tractor Repair
Holy Cross, Iowa
563-552-1615 or 563-590-1973
