Allis Chalmer CA
Deborah
06-30-2005 14:54:56
I have a (I think it's a 1953) Allis Chalmers CA and it runs great. I was clipping and the rear left wheel started making a noise and now it will run but won't go. It's like the gears are striped or something like that. Any advice where I can get the parts I need. Or any advice at all would be helpful. Thanks
1755
07-04-2005 16:09:32
 Re: Allis Chalmer CA in reply to Deborah, 06-30-2005 14:54:56
It could be the Hand clutch sliped enough it wore threw the clutch lining
jayw
06-30-2005 18:10:55
 Deb in reply to Deborah, 06-30-2005 14:54:56
Deb
Has the hand clutch been bolted together our dose it still work, Some times they bolt them together when they quit working and the bolts may have sheared off.
LWD
06-30-2005 17:01:41
could it be the right axle kicked out?
JMS/MN
06-30-2005 14:58:42
Could also be a bad bearing that is worn to the point that the gears are separating rather than meshing. Take it apart to see what the problem is. Bearings should be available at dealers, parts stores, etc. Gears and shafts might be available at salvage yards. Parts Express yards are at 1-800-533-5304. Or try Worthington Ag- one of their yards.
