RC Allis Chalmers
David Mullis
06-29-2005 19:33:17
I have a Allis Chalmer tractor and it is stamped Tractor No. RC4300. I can't find any info on a RC. What is the differance between it and a WC? And where can I find more info on it? Thanks
LWD
06-30-2005 17:18:36
 Re: RC Allis Chalmers in reply to David Mullis, 06-29-2005 19:33:17
some parts are hard to find, I`m looking for a fly-wheel and pressure plate. some of the tractor pullers got most of the rear ends around here.
Tramway guy
06-30-2005 08:49:05
The rear end was slightly different internally. The pinion gear did not have the extra bearing that the WC does on the rear of the Pinion shaft. I think maybe the rear end or final drive ratio was slightly different also.
JMS/MN
06-30-2005 14:52:39
 Re: RC Allis Chalmers in reply to Tramway guy, 06-30-2005 08:49:05
Yes, the ratio was different, to accomodate the small engine. That's why pullers look for RC rear ends. AC wanted to make a cheaper poriced tractor than the WC, and still use its implements, but farmers were not impressed with the lower power. WWII was a good excuse to cease production, and not restart after the war.
Texas Denny
06-29-2005 20:17:23
They made the RC for only three years - 1939 to 1941. The total production was 5501 which is small compared to many other AC tractors like the WC and WD. The RC used the same frame as the WC. The WC at that time had a 201 ci engine while the RC had a 125 ci engine like the C which debuted in 1940. All WC implements could be used with the RC which was AC intent and expected draw. However, it didn't draw buyers as they expected. The C sold 84000 in 10 years of production. On a yearly basis that is 1830 for the RC vs 8400 for the C. So AC dropped the RC after only 3 years in favor of the C.
