WD PTO parts
baldie
06-29-2005 08:07:43
I am looking to buy a WD the pto does not work. Are new parts available to make repairs. Such as grears, shafts or what ever is required. It has not been disassembled so I don"t know what parts are required.
Kevin Bismark
06-29-2005 18:21:21
 Re: WD PTO parts in reply to baldie, 06-29-2005 08:07:43
What do you think is the problem, I think you should be able to find what you need without much trouble, the guys gave good advice about getting them, but seems pretty simple, if I remember right the pto clutch deal is a rod that goes down under the transmition a little box with the pto coming out of the back, can"t be much there, maybe a bad set of fingers on the deal that slides the gear in, never had one apart but don"t think there is much in there...
old
06-29-2005 08:11:57
Yep you can get most of the parts new or used. I have a WD parts tractor with a PTO on it I'd sell.
baldie
06-29-2005 09:42:38
 Re: WD PTO parts in reply to old, 06-29-2005 08:11:57
Thanks Old,
If I were to buy the tractor how much would you want for the pto assembly. Also could you tell me where the parts are available new. Thanks
old
06-29-2005 09:56:30
 Re: WD PTO parts in reply to baldie, 06-29-2005 09:42:38
An arco-ag dealer should have them or be able to get them.
But they are very high. I'd have to get $100 just for the shaft and thats less then half of what a new one would cost. I'd first check to see what you might ned to repair it since as I said parts for it are very high.
