Coil + or -
Dale13
06-23-2005 15:10:41
On a negative ground 12 volt system do the points take voltage from the positive side of the coil or the negative?
old
06-23-2005 15:28:52
 Re: Coil + or - in reply to Dale13, 06-23-2005 15:10:41
Here it is easy if the battery is + ground the dist. side of the coil is to the +. If its - ground the dist. side is the - . The way the system works is the coil is shorted to ground when the points are closed and the coil fires or sparks when the point open.
Gatz
06-23-2005 15:27:42
The + comes from the ignition (ballast).
The - goes to the points terminal.
