differance from wd45 to d17
mark1952
06-23-2005 07:49:25
what is the differance in the engins from a wd45 to d17? I want more power
DanD.
06-23-2005 12:11:06
 Re: differance from wd45 to d17 in reply to mark1952, 06-23-2005 07:49:25
There are several significant differences between the engines. They do have the same bore and stroke to give 226 cid and some parts like the sleeves are the same. However, the D17 block has a reinforcing ridge all around the outside of the block near the bottom. The D17 has larger main bearings, higher compression ratio and its rated speed is 1650 RPM vs. the 1400 of the WD45. Newer D17's have the full flow oil system and the heads are different on the newer D17's and use the longer reach spark plugs.
Phill Snartland
06-23-2005 09:05:07
I think it's the same 226 cid engine, the only difference is that the governor on the D-17 is set at 1600 rpm, compared to the WD-45 at 1400 rpm. The difference in speed makes the difference in hp.
Good Luck!
