CA engine in a B tractor?
Murphy
06-22-2005 12:34:38
I'm way past ready to get my allis out of the weeds. A search for running engines turned up an engine out of a CA. What, if any, are the differences in engines?
Will my waterpump, mag, starter, torque tube, etc., bolt up or are there differences?
I don't know the year of the engine but my allis is a 1941 if that makes any difference.
payne
06-22-2005 13:40:06
 Re: CA engine in a B tractor? in reply to Murphy, 06-22-2005 12:34:38
Yes to all. The casting for a B, C, and CA are the same exept for the bolt holes for the generartor but the CA has them. The only difference is the bore. If you dont care about originality than yeah it will work fine. If you do than i suggest finding a BE engine off of a B.
Murphy
06-22-2005 14:10:31
 Re: CA engine in a B tractor? in reply to payne , 06-22-2005 13:40:06
Are you saying that the CA has both sets of bolt holes?
BTW, thanks for the info.
steve(ill)
06-22-2005 15:44:15
 Re: CA engine in a B tractor? in reply to Murphy, 06-22-2005 14:10:31
the original motor in the B was a BE, after the C went in production the BE was increased in bore size and called a CE motor. it was the same for the next 20 years, so yes, a CA motor (CE) will fit in the B tractor that had a BE motor. ---- the CE had a electric starter and a generator which might not be on the old B. there are a couple extra bolt holes ont eh block for the generator mount. the starter drive is all in the torque tube and flywheel modification, not the motor. the CA would have a distributor and coil to start, the BE motor would be a magnito, but either can be installed in either motor.
CHALMERSBOB
06-22-2005 19:07:39
 Re: CA engine in a B tractor? in reply to steve(ill), 06-22-2005 15:44:15
ELDON IS RIGHT ABOUT THE MAG. 41 B's ALSO HAD ELECTRIC START. POSSIBLY AS AN OPTION. BUT IT WAS AVAILABLE AS EARLY AS 40. PUT THAT ENGINE IN THE OLD B, AND IT WILL WORK GREAT. LOL BOB
Eldon (WA)
06-22-2005 17:14:25
Early CAs had magnetos.....
DanD.
06-23-2005 12:15:47
 Re: CA engine in a B tractor? in reply to Eldon (WA) , 06-22-2005 17:14:25
third party image
As you can see from this photo of my CA, Eldon is correct about early CA's having magnetos.
