ac 170 runs for an hour then stops
scott reed
06-20-2005 06:55:30
My grandpa has an AC 170 that runs for about an hour then stops. He goes to lunch, comes back and it runs for about an hour then dies. This keeps happening. Any suggestions?
Davey in Mo
06-22-2005 04:26:58
 Re: ac 170 runs for an hour then stops in reply to scott reed, 06-20-2005 06:55:30
You have to narrow it down to lack of fuel or ignition. Next time it stops, loosen the plug at the bottom of the carb to see if any gas dribbles out..... ..... or give it a shot of ether to see if it starts/coughs again when cranked. That will confirm fuel flow. I suspect an electrical problem. Carry a spare spark plug with a real wide gap. When the engine dies, pull one of the wires, insert the extra plug and ground it to the block. PUT THE MACHINE IN NEUTRAL. Crank and look for a spark. If none, then it's probably the coil ALTHOUGH it could be the on-off switch.
scott reed
06-20-2005 09:20:45
Thanks. I will let him know.
Doug in OR
06-20-2005 09:19:21
Possibly the coil. Possibly the gas cap is not venting. Possibly the valves are adjusted too tightly. Just to add a few possibilities.
Wild Bill
06-20-2005 09:18:49
I"d bet my last dollar that the coil is bad (if it is a gas burner)
old
06-20-2005 08:29:50
If its a gas rig I'd go with a bad coil as others have said. If diesel I'd say he needs to change the fuel filters.
Tramway Guy
06-20-2005 07:21:16
A couple of things come to mind. Maybe the vent (in the filler cap) for the gas tank is plugged, or perhaps the ignition coil is faulty.
Gatz
06-20-2005 07:20:16
gas, or diesel?
If gas, it could be that the coil is failing when temps rise.
