wd-45 diesel rear end the same as a d-17 gas?
m.jamison
06-19-2005 18:43:40
I was told that a wd-45 diesel rear end was the same ratio as the d-17 rears and would work. I'm looking at changing the rear end in my wd-45 gas to slow my wheel speed down.
LWD
06-20-2005 00:22:25
 Re: wd-45 diesel rear end the same as a d-17 gas? in reply to m.jamison, 06-19-2005 18:43:40
The gears in the WD are a litte slower than the WD45 gears.
JMS/MN
06-20-2005 11:49:51
 Re: wd-45 diesel rear end the same as a d-17 gas? in reply to LWD, 06-20-2005 00:22:25
I don't know if the ratios were different between the straight cut and later tranny gears, but each tractor had different standard and oversize tires available, which would make a slight difference in outside diameter, and thus speed.
old
06-19-2005 19:52:47
That might be true if the D-17 is a series 1 allis liked to try to put a bigger engine in to there tractor but use rear ends from the tractors they had been makeing and thats why at times they have tractors that have tranny problems
JMS/MN
06-19-2005 19:27:25
A long-time AC mechanic recently told me the same thing- in fact he mentioned others that share the same parts. Easiest way to check is with parts books for both tractors you want to compare.
