AC 185 3 point lift arms not going down
streaker
06-18-2005 11:52:00
OK all you Allis Pros, I have a 185 that when I move the lever for the three point hitch arms to go down, they won"t. When I park the tractor for a couple of days they go down on their own while not operating, but when I am operating it they wont. Does this sound like a simple fix? What and where should I start looking. Thank you in advance!
Sid
06-19-2005 13:16:27
 Re: AC 185 3 point lift arms not going down in reply to streaker, 06-18-2005 11:52:00
Check the draft positioning control.
Nathan Webb
06-18-2005 20:38:43
I"ve got a 190 xt if your tractor uses a hydro block mounted on the lever side of the tractor. under the seat mounted on the side frame you will want to get the proper spec and test your outlet pressure to see if it is high enough. Mine wasn"t had to put a small washer in due to the springs getting weak. This may not be it for you but it was for me.
