d-14
paul melton
06-18-2005 07:42:28
I have a D-14 thats jumps out of gear. What can I do to fix it?
Don Dittmar
06-20-2005 04:21:26
 Re: d-14 in reply to paul melton, 06-18-2005 07:42:28
What gear does it jump out of? These transmissions are very picky as everything has to be just right. My D14 jumped out of 4th gear, so I tore it down and found all gears badly worn. I replaced all of them with gears out of a parts tractor I bought for 75.00. The gears I put back in it were in 10 times the shape as the ones a took out, now it will not stay in second and 4th jumps out every so often. After all of this, I think the best thing to do is bite the bullet and go to your local AGCO dealer and buy the gear you need new. It is expensive, but when you are done it will be right. I am going to do the same thing to my D14 when I finish the JD 720D I am working on now.
Dale(MO)
06-21-2005 01:58:23
 Re: d-14 in reply to Don Dittmar, 06-20-2005 04:21:26
Be sure the shift collar is OK, too. That could be half the trouble. They, too, are not cheap, but a working tranny is a lot handier than one you can't work with.
Good luck,
Dale
