WD45 Power Steering Problems
WD45 Bob
06-16-2005 09:51:30
I have a WD 45 Diesel that has an add-on Charlynn power steering pump. The reservoir pressurizes and blows all the oil out of the breather. It worked for years, so I believe everything is sized right. I looked in the archives, and found that John Carpenter had the exact same problem around 8/9/01, but I cannot tell what he finally found was the problem. Any help would be greatly appreciated.
Dave Grubb
06-16-2005 13:56:49
 Re: WD45 Power Steering Problems in reply to WD45 Bob, 06-16-2005 09:51:30
There is a filter on Ebay that is for an Eaton/Char-Lynn pump that should work. You might be able to get one at NAPA also as the early Ford products used thisstyle pump.
Dave Grubb
06-16-2005 13:28:28
There is a cartridge type filter in the reservoir. Maybe it is finally clogged if it has never been changed.
