D17 Goes Slow
Mike Nixon
06-14-2005 05:18:40
Hello all,
I just bought a D17 and when test drove her she ran fine. Now I have her at home and when in 3rd or 4th she starts slow and it seems that she can only reach 3-4 miles per hour. Any ideas?
I am changing the rest of the fluids tonight, put 30 SAE in Engine oil and Hyd Trans in the traction booster/Hydraulics. Putting 80W90 gear lube in the Trans tonight. Think that will help? I have no idea what the guy I bought it from had in her.
Thanks,
rednight (IL)
06-14-2005 06:53:12
 Re: D17 Goes Slow in reply to Mike Nixon, 06-14-2005 05:18:40
third party image
Does this slipping occur even when you have the power director clutch lever in the high range and low range? Depress the top button and move lever forward or backward until it locks in position and clutch should engage in that range. If it does not you have clutch/gear problems.
Mike Nixon
07-31-2005 06:03:13
 Re: D17 Goes Slow in reply to rednight (IL), 06-14-2005 06:53:12
Now it's even worse. She won't go at all in 3rd and 4th with the PD in high or low. Did I put the right fluids in? I have been told it's the clutch slipping. A service tech here said it was going to be about $350 just to break her apart...Yikes!
Please respond,
Thanks
Mike
old
06-14-2005 06:25:43
Clutch slipping or the HI/LOW not working/engageing
