WD - Broke while Bush Hogging
Joe Berendzen
06-14-2005 03:55:27
I was pulling my 6' Bush Hog in the field and I got too close to the fence-row and hit a stump. Instead of shearing two bolts in the flanges on the drive shaft on the Bush Hog, something broke inside the tractor. It stopped dead and when I started it back upand put the PTO out of gear it was still in a bind. When I tried to let out the clutch it sounded like something inside was grinding. I put it in reverse to get off of the stump and it freed up then. I was able to drive the tractor back to the barn, but the PTO won't engage. I do hear an occasional scraping sound inside while driving, like loose parts flopping against something. I didn't have time Sunday eve. to look into it, so I'll be wondering all week what I tore up this time. Any ideas what I broke? Could I be so lucky as to have some shear bolts inside? Or is it a gear? Thanks, Joe
souNdguy
06-15-2005 08:15:28
 Re: WD - Broke while Bush Hogging in reply to Joe Berendzen, 06-14-2005 03:55:27
Did this mower not have a shear bolt?
Soundguy
Joe In SC
06-15-2005 09:11:06
 Re: WD - Broke while Bush Hogging in reply to souNdguy, 06-15-2005 08:15:28
Yes, It had two shear bolts in a pair of flanges in the shaft. I just bought the Bush Hog a couple of months ago and didn't check to see that they were grade five bolts. I was surprised that the single bolt in the stub shaft didn't shear.
Dean
06-15-2005 12:42:46
 Re: WD - Broke while Bush Hogging in reply to Joe In SC, 06-15-2005 09:11:06
As Kevin said, WDs and 45s are not known for stout PTOs, and PTO problems are not uncommon when using bush hog type mowers, shear bolt, slip clutch or otherwise.
Dean
souNdguy
06-15-2005 10:07:15
Are you saying that it would have had to shear two bolts at once? That doesn't sound like a good setup.. to attest to that.. you have a broke AC pto...
Soundguy
Joe in SC
06-16-2005 02:57:54
 Re: WD - Broke while Bush Hogging in reply to souNdguy, 06-15-2005 10:07:15
Yep, The pair of flanges inthe Bush Hog shaft seem to be original equipment. Maybe I should try to contact Bush Hog and find a manual on that model to verify what should be used as shear pins/bolts/whatever. At any rate, I found a donor tractor that is supposed to have good PTO gears in it. I'll check it out and go to work here in a week or so. Thanks, Joe
souNdguy
06-16-2005 06:57:05
 Re: WD - Broke while Bush Hogging in reply to Joe in SC, 06-16-2005 02:57:54
Wow.. again.. sorry about what happened.
Most mowers I see with a shear pin have the pin at the gearbox shaft where the pto yoke attaches, and not on a flange.
Seems like 2 bolts on a flange are going to make it real hard to shear.. even if they are grade 2.
I'd deffinately get the manual, and check that out. I'd also get a 99$ slip clutch and adjust it a tad loose.. probably cheaper than fixing that tractor.
good luck.. keep us posted!
Soundguy
Kevin (FL)
06-14-2005 19:51:52
Hi Joe,
The WD isn't known for a bullet-proof PTO setup. My neighbor's WD broke about 15 years ago and he never fixed it. Bought another tractor instead that had a good PTO. Anyway, the extension shaft (the external one that engages into your mower shaft) has a bolt through it that connects to the stub shaft. That may have sheared or you may have broke either the slider gear or the idler gear. I believe the slider gear is grooved to fit a key on the stub shaft--maybe something fouled up there. Either way you need to drop the PTO assembly and check things out. Hopefully, if you have an early model tractor with the cluster gear setup, you didn't break a gear on the cluster, or one of the lower gears on the later model transmission. Lots more work there than just something broke on the PTO parts.
old
06-14-2005 06:24:00
My guess would be a gear, but thats only a guess. If you find you need parts I have a WD that I'm parting out. Engine how 0 oil preassure, but still ran good.
