12 volt conversion
Jeff in OK
06-13-2005 16:49:12
I've got a 49 wd that I love dearly but I seem to be going through coils or condencers every 100 hrs or so although not that costly it is still very annoying does any one know if there is a kit to convert from that fmj fairbanks mag to a dist. off the governer. or possibly am I doing somthing wrong. thanks for the help.
jeff
Steve in N.J.
06-15-2005 19:37:01
 Re: 12 volt conversion in reply to Jeff in OK, 06-13-2005 16:49:12
Jeff,
We service and rebuild magneto's. We specialize in Fairbanks. We also offer a complete mag to distributor conversion kit, so we can help you either way. We take the mags in on trade towards the conversion too if you wanted to trade it in. We also have an optional electronic ignition available. Drop us a line if interested. Be happy to help ya out....
Steve@B&B
[email protected]
souNdguy
06-15-2005 08:20:47
Your mag is going thru coil and caps?
I've seen lots of people gut their mags, and use an external coil and condensor.. and just use the mag housing for the breaker plate and breaker contacts, and the drive. I've seen alot of IH tractors that way. Then you can use whatever coil is appropriate fro your tractor voltage.. like a napa IC14SB 12v coil.. etc.
Soundguy
old
06-13-2005 19:27:03
Well its a mag going to 12 volts will not hepl you. You might want to try magneeders.com he may know what your problem is.
Jeff in OK
06-13-2005 20:05:38
 Re: 12 volt conversion in reply to old, 06-13-2005 19:27:03
thanks old but what I was hoping is replaceing the mag. with a dist. and converting to 12 volt. and I will try magneeders.com
old
06-13-2005 20:45:11
 Re: 12 volt conversion in reply to Jeff in OK, 06-13-2005 20:05:38
I have a dist, but its on an engine so I would prefer to sell as a running engine not just parts off of it, the engine need to be rebuilt but it did/does run
Jeff in OK
06-14-2005 17:23:50
 Re: 12 volt conversion in reply to old, 06-13-2005 20:45:11
Thanks old but will pass I guess I was just thinking out loud.
