WD 45 Carb Question
Pete Churilla
06-12-2005 18:00:15
I finished the restoration of my wd45 and after a drive in the local parade the carb was cold and showing condensation,is it possible I am running too lean,also please advise your carb setting procedure.
Thanks Pete
old
06-12-2005 19:15:31
 Re: WD 45 Carb Question in reply to Pete Churilla, 06-12-2005 18:00:15
Cold/iceing carb is pretty normal. As far as setting you start with the idle screw at about 3/4 turn out and the main jet at abour 1-1/2 but thats just a starting point from there you need to adjust for what you engine likes/needs
