wd or wd45?
eric kemp
06-11-2005 16:58:56
i just bought what i was told was a 1955 wd45,but im thinkinh\g it might e just a wd.what are the diferances and how can i tell,i read the post below about the serial number but i cant find one as of yet.please help,thanks.
Scott, MO
06-13-2005 12:44:32
 Re: wd or wd45? in reply to eric kemp, 06-11-2005 16:58:56
had the same problem with one I bought, it turned out to be a 49 WD, that had a WD-45 engine in it. there is a visual differance in the engines. Someone correct me if I'm wrong, The WD-45 had a cover bolted to the side of the block above the oil pan rail on the left side as you were sitting on the tractor.
Dean
06-14-2005 05:03:36
 Re: wd or wd45? in reply to Scott, MO, 06-13-2005 12:44:32
Bolt-on cover was on right side of engine behind mag/distributor on WD engines but not WD-45 engines.
Dean
napaguy
06-12-2005 08:41:15
straight shifter...wd...curved shifter..wd45
eric kemp
06-12-2005 20:51:21
 Re: wd or wd45? in reply to napaguy, 06-12-2005 08:41:15
it has a curved shifter but moto prefix is wd,going to take more paint off to see if i can find the serial number.
Texas Denny
06-12-2005 06:59:06
Left and right are based when sitting on the tractor seat.
Texas Denny
06-12-2005 06:55:04
This is an excerpt from the "serial number" portion of this site.
1953 146607
1954 160386
1955 190993
1956 217992
1957 230295
The Serial Number is located on top of left differential brake housing.
This gives the staring serial number for each year. It says the number is on the left brake housing. Every WD or WD-45 that I've seen has one there. If the tractor has been painted a lot, the numbers might be hard to read.
allcie
06-11-2005 17:34:32
The number that I'm going by is on the left side under the seat at about 11 o'clock by the bolted on plate. I'm thinking mine might be a 55. Not sure. But was told it was a 57 wd45.
Don J. Etnier
06-12-2005 16:29:09
 Re: wd or wd45? in reply to allcie, 06-11-2005 17:34:32
Having problem identifying year of manufacture. Looked under carb intake, it says "45 53502". I know its a WD45 but can"t find year. Any suggestions?
eric kemp
06-11-2005 18:26:30
i must be blind as a bat,i see no number.right side or left side,right side would be under the seat right???i dont know!
Brian G. NY
06-12-2005 13:55:32
 Re: wd or wd45? in reply to eric kemp, 06-11-2005 18:26:30
Look at the rear vertical surface of the differential at the LH brake area. Look for a smooth area between the brake spring hole and the brake adjusting bolt/locknut. The serial number is stamped here and will be prefixed by WD regardless whether it is a WD or WD-45. Look for the engine serial number on the side of the block near the carburetor intake. A WD engine will be prefixed with WD and A WD-45 engine will be prefixed with 45.
