D-14 losing power, etc.
Jeff Steininger
06-10-2005 09:11:53
This may have been gone over, but I don't have time to search. I got a D-14 2 yrs ago. Ran pretty good when I got it, bush hogged and everything. I've replaced sparks & all wires (2 weren't even firing!) , new gas filter & bowl, engine oil each year - basic stuff. Ran GREAT... until recently. Starts up fine, runs fine 'til I really start working her (bush hog). Starts to hesitate badly, backfires repeatedly then dies. Once it cools down, same pattern. I was going to replace the thermostat - it's already been removed. Coolant looks fine. Temp. gauge doesn't show it's all that hot, not sure how accurate that is. Any ideas??? Getting desperate... weeds growing fast
Jeff Steininger
06-11-2005 14:24:32
 Re: D-14 losing power, FIXED - not! in reply to Jeff Steininger, 06-10-2005 09:11:53
Thans guys for the ideas. Talked to a guy who thought the use of low octane unleaded for many years dries out the valves, causing them to stick. - Backfires. Sounded plausible. Recommended 'Sea Foam' (had never heard of it) in the gas along with some 2 cycle oil to loosen things up. The can said its good in the crankcase oil too, so I put 3/4 in the tank, and the rest in the oil. Added 2 cy. oil to fuel as well. Still backfired/lost power. Got a new coil the next day and all seemed well! Mowed a good 20 min. no problem! Thought maybe the slicker fuel settled in and/or the coil was the culprit. Of course at that point ...POW! POP...etc. I'm losing hope.
Okieboy
06-10-2005 12:07:52
 Re: D-14 losing power, etc. in reply to Jeff Steininger, 06-10-2005 09:11:53
Coil breaking down or could be the condenser, I kinda doubt a fuel problem. Okie
old
06-10-2005 09:37:26
Your coil maybe going bad, or it could also be lack of fuel at the carb. When the backfire like that most of the time its because it isn't get fuel as it should. Pull the drian plug at the bottom of the carb, gas should flow out just like you going. If it doesn't then you have a clogged fuel line or a clogged carb.
