WD Engine troubles
Tony Z
06-09-2005 20:00:07
Hi,
I recently purchased a 1954 WD. It started but ran a liitle rough when I bought it. I put new plugs in it and changed the fluids and what not. It had a full tank of gas so I did not change that. I started it a few times and it started right up, but you couldn"t put it under a load or it would die out. Once it warmed up a little you could drive it, but it never ran well. I only ran it twice and then I replaced the muffler and started it up to try to check things out and burn some of that gas off. It ran about 10 - 15 minutes and still wouldn"t run under a load and it was blowing quite a bit of black smoke and oil is running down the engine block on the muffler side. I am not sure if it is coming out around the muffler, or the head gasket. Anyway, it died and now I cannot get it started. Does anyone have a recommendation of where to start first? Thanks,
Tony Z
old
06-10-2005 08:22:13
 Re: WD Engine troubles in reply to Tony Z, 06-09-2005 20:00:07
I'd say you have a carb problem and gas problem, old gas works good to kill weeds but that about it, trying to run it in an engine is bad news. As far as the oil leak I'd say valve cover gasket. I'd drain the gas tank and rebuild the carb and replace the valve cover gasket.
John (MO)
06-10-2005 07:03:17
Tony, I'd also drain the gas tank and see just what may be hiding in there. Getting the carb working good isn't going to help if you can't get good fuel to the carb. I think there is a fair chance the plugs are fouling with oil that is coming past the valve guides. That can be a problem in well used engines, although not always one that has to be corrected. If you get a good fuel/air mix into the engine and a good hot spark to fire it off, burning a little oil along may not really cause you any problems. If the fuel/air and spark aren't good though, the extra oil can really compound the problems. If you have some oil getting inside the cylinders you might try spark plug extenders to kind of keep the plugs back out of the way of the oil. A valve cover leak, while nasty, shouldn't cause you problems with the way the engine runs.
Tramway Guy
06-10-2005 06:30:39
Might also check the air intake system. Try disconnecting the hose for a few minutes and see if it runs better. The air cleaner can get plugged up.
Tony Z
06-10-2005 06:06:53
Hi, thanks for the comments. I think your right. It may be carburation. It was blowing some black smoke when it was running. The oil pressure is real good, and someone did put new plugs in it before I bought it. It won't start, but maybe the plugs are fouled out now from running over fueled. I will try to pull them tonight. The carb does look like it has not been touched in years.
Tony Z
J.C. IN AZ.
06-10-2005 21:08:57
 Re: WD Engine troubles in reply to Tony Z, 06-10-2005 06:06:53
Hi: I know this may not apply to your Problem but my Dad had a Farmall M which would quit under Power repeatedly and then it would run alright for days. Come to find out a whole Oat Seed had got in the Fuel Tank and on occasion would get drawn down into the Neck of the Tank Drain effectively cutting off the Flow of Fuel.Maybe there is some loose objects in the Tank causing your problem.
farmweld
06-10-2005 05:39:12
i think gene has nailed it, allthough 70 PSI for compression sounds a little high. start off with little things before spending lots of money.
hope this helps
farmweld
gene (Missouri)
06-09-2005 20:55:36
Oil on manifold side of block. Probably the valve cover gasket. This is not a big or expensive problem to solve. There isn't really any way or oil to get into the combustion chambers except through the valve stems or sucking past the rings. Do not replace the valve cover gasket until you get the engine running decently - may be a waste of money.
Remove the hood. Do a compression check - if reasonable (70PSI or better and fairly even) then do a complete tune up. Points, plugs, time the engine, adjust the valves. Swap out the coil with a know good one.
I would remove the carburator. Strip, clean and reassemble.
Has this tractor been sitting for a while - months or years?
Poor engine operation. 1st guess. Carburation - over fueling. Look for sticking float/needle valve - gummed up carb. You might try some carburator cleaner - added to the fuel tank - from the auto parts store.
2nd guess Carburation and engine timing problem.
Good luck.
Gene
