WD Steering Wheel Removal Advice?
Russ Behm
06-07-2005 08:04:58
I have a 1949 WD and would like to remove the steering wheel so it can be replaced. I would like some advice on how to remove the steering wheel.
Thanks
pj
06-09-2005 06:47:52
 Re: WD Steering Wheel Removal Advice? in reply to Russ Behm, 06-07-2005 08:04:58
Take a small grinder and cut off wheel and cut the hub right next to the pin in 2 places.Once you you do that take a chisel and knock off the hub and drive out the pin may need a little heat.
Bob in Wi
06-07-2005 12:04:50
Did it on my 1950 wd. Tried to heat up the center hub of wheel to drive out the taperd pin that goes threw the shaft. Didn't work for me. I had to use the tourch to CAREFULLY cut off the old wheel with out damaging the shaft in the center. I ended up using a roll pin to secure the new wheel to the shaft. I havn't used the tractor enough to garantee the pin don't come out.
dupontsniper
06-08-2005 07:33:58
 Re: WD Steering Wheel Removal Advice? in reply to Bob in Wi, 06-07-2005 12:04:50
I just drilled my old pin out and used a puller on the shaft, took a little finaggling and a little cussing, but it came off. I also used a roll pin on the new steering wheel, I used one that I really had to pound in, figuring this wheel is on for the rest of my life anyhow. It works fine.
