WD or WD-45 Engine kit
Guyzoo
06-06-2005 07:25:12
Hi guys, I needs to know if a WD-45 kit will fit in a WD. I dont have the serial number of the engine but it has a distributor, a plate for the push rods, a tall head and a curved shifter.
the serial number of the tractor is WD112198 wich I think is a 1952 WD. also I forgot to mention it has a 4.5 inch crank and straight cut gears in trans
Aaron SEIA
06-06-2005 16:46:12
 Re: WD or WD-45 Engine kit in reply to Guyzoo, 06-06-2005 07:25:12
If you know it has a 45 crank and a 45 head, then not only would a WD45 kit fit, but it'd be the one you would want to use. Or go with a D17 kit and swap out the rod/main bearings and misc gaskets that won't fit.
Aaron SEIA
