N-62 engine shears pin in oil pump
Irv Plitzuweit
06-04-2005 10:23:56
Bought tractor with N-62 engine in basket. Got engine assembled and started and no oil pressure. Checked oil pump and pin was sheared. Replaced pin and put in slightly thinker gasket, thinking clearance might be compromised when assembled. Started engine and had good oil pressure. Next time I started engine, no oil pressure. Plenty of oil, oil pick up in crankcase is O K and lines are not plugged. Have not yet removed engine to look at pump, but suspect pin is sheared again. Suggestions?? Thanks for any help.
rustyjunk-IN
06-05-2005 00:10:11
 Re: N-62 engine shears pin in oil pump in reply to Irv Plitzuweit, 06-04-2005 10:23:56
i could be way off here but i had the same problem with an old ford F250 because of debree in the pump it locking it up and shearing the pin.[it actually kept shearing the pin in the distribitor shaft than ran to the pump.could be wrong but its a thought.
