G- Allis Chalmers Engine
Robin Babb
06-02-2005 10:16:53
I am in need of an engine for G Allis Chalmers tractor. Could get by with good used crank if no one has engine. Engine in my tractor is an N-62 Continental, will anything else work? Thanks,
RBabb
bw in mo
06-04-2005 18:24:52
 Re: G- Allis Chalmers Engine in reply to Robin Babb, 06-02-2005 10:16:53
I have a used crank ,pistons & rods for sale. call 573 324 3693 after 9:00 CDT ask for Billy.
Plant Doctor
06-03-2005 05:39:18
Robin: Try Kens Forklift Trucks at (856) 697-1307. The N62 was used in several different forklifts and Ken has always been able to find new and used parts for me. If your crank is not broken you may want to consider getting it welded and resized. I have had a couple resized and as far as I know they are still running.
souNdguy
06-02-2005 21:28:12
third party image
I think I just saved you some money.. here's a couple links to a fellow in CA that I bought some parts for my G from. The parts were reasonable, and as advertised.
He has a crank pulled from a pony inthe G parts section.. 125$.. says excelent condition.. has head, pistons.. oil pump.. distribuitor.. cam.. crank gear.. clutch.. timing cover.. etc.. tranny case.. pretty much everything but a block..
here is the engine parts link...
Link
And his main allis link link:
Link
And his main link:
Link
I've no conenction to this guy.. but he has good salvage parts.. lots of pieces of my G came from him.. here's a pic of mine. Look under soundguy in the tractor photo section to see more. i made a 'satrt to finish' pictoral history of much or hte repair and body work and painting and parts assembly.
Soundguy
Dean glover
06-02-2005 20:01:19
Hello, All Allis G tractors used the Continental N-62 engine, as did the Massey pony and Earthmaster. The block used in the G is different however. On the G the starter goes into the bell housing area from the front and on the other ones it goes in from the rear. Thus, the G block has a built in provision for the starter and the others do not. The G dosen"t use a Cub engine which is made by International and is totaly different.
cdmn
06-02-2005 21:06:43
 Re: G- Allis Chalmers Engine in reply to Dean glover, 06-02-2005 20:01:19
IHC used a 1Y Continental engine for combines. Don't know if it shares internal parts. It's small.
jason(ma)
06-02-2005 19:17:57
Have you looked at the ones sold by the company formerly know as middle tractor. that is code , filter keeps me from saying the real place
Texas Denny
06-02-2005 14:59:18
My books say the Cub had a Farmall engine. The Massey Harris Pony does use this Continental engine. If you don't have any luck on this site, try the Massey board. And try Ebay. There are parts for these engines there frequently. I just saw a block for a G about a week ago - and a crank shaft plus other engine parts.
Dons918
06-02-2005 14:38:13
I think the Farmall Cub is the same engine.
