allis c hood bolts
jk
05-30-2005 18:29:14
what size and lenth bolts does a c hood take? also the mouting pad by the fly wheel, does that go all the way threw or does it bottom out? i need to know to moth a weight rack but i don't want to get too long of a bolt and possible hit the fly wheel
thanks
jk
06-05-2005 15:07:07
 Re: allis c hood bolts in reply to jk, 05-30-2005 18:29:14
ok how may bolts do i need? i see 4 places for bolts aroud the radiatior and it lookes like the other end of the hood goes under the gas tank strap. i have the hood, but it was off when i got the tracotr and i don't know why, i want to get it put back on its driving my nuts.
Butch(OH)
05-31-2005 08:07:42
The original fastener was a slotted truss head machine screw. They differ from a regular screw in that the head diameter is larger. Probably not going to find them at a hardware store but you can order them at a fastener house or through McMaster Carr. They are 5/16 coarse thread, I believe the box I have is 3/4" long. Dont go too long as Steve said, you can also crew the top two through the radiator causinga big leak.
Dick L
05-31-2005 11:08:24
 Re: allis c hood bolts in reply to Butch(OH), 05-31-2005 08:07:42
ACE HARDWARE STORES has them in the slide out fastener boxes by the each. At least the one I go to does. Not the cheapest place to buy them but 8 of them of them at a time don"t seem to break the pocket book.
steve(ill)
05-30-2005 19:16:33
hood bolts are 5/16 dia, about 3/4 or 1 inch long. watch the two on each side middle of the radiator. too long will get close to the fan blades. i have heard of guys putting long bolts into the fly wheel housing then "no crank" so i guess you can get them too long and they do go thru. bolts should go into a hole 1.5 times the diameter of the bolt, so a 5/8 bolt should have 15/16 of thread. a 1 inch bolt should have 1.5 inches of thread, etc. that is good engineering, most are lucky if you have 1 times.
