pulling tractor help
Derek R.
05-29-2005 13:30:28
I HAVE AN ALLIS WD I PULL ON THE WEEKENDS FOR FUN, I HAVE A D-17 ENGINE (NOT A KIT) IN IT OUT OF A GLEANER COMBINE--ENGINE IS A STOCK D-17 NO MODIFCATIONS AT ALL, THE TRACTOR HAS NO GOV. AT ALL ITS EITHER WIDE OPEN OR IDLE FROM THE PUSH/PULL CABLE THAT WAS STOCK ON THE COMBINE, THE TRACTOR PULLS GREAT IM VERY PROUD OF IT BECAUSE IVE DONE IT ALL MYSELF, IT HAS STOCK IGNITION, POINTS,COND. RESISTOR FOR THE ALTERNATOR AND I DO HAVE A FIRE BREATHER COIL ON IT BUT IM WONDERING IF SOMEONE WOULD BE WILLING TO HELP ME OUT ON A FEW QUESTIONS OR IDEAS TO MAKE IT PULL BETTER, ITS A 3RD OR 4TH PLACE TRACTOR NOT A WINNER AND I DONT WANNA BE ONE JUST DO A LITTLE BETTER, AC IS A HOUSEHOLD NAME WHERE I LIVE BUT THE OLDER GUYS HERE WONT LET OUT NOT ONE "SECRET" TO HELP A YOUNGER GUY OUT IN PULLING, BUT IF SOMEONE WOULD HELP ME A BIT, POSSIBLY IN THE CHAT ROOM OR EMAIL CAUSE I HAVE SOME QUESTIONS, A MILLION THANKS TO ANYONE WILLING TO HELP ME OUT THANKS AGAIN.
dej(JED)
06-01-2005 07:31:18
 Re: pulling tractor help in reply to Derek R., 05-29-2005 13:30:28
Jeff pretty well said it all. No one thing applies to all tractors. I pull a stock tractor and it pulls well , but only once have I ever been in first. When I think I have it figured out, I do terrible and then when I don't care I do well. Tires , track and hitch are the key factors. Just keep trying until you get it right.
Any more 4 and 5th's would look good to me.
Jeff Oliver
05-30-2005 06:02:13
if your pulling in farm stock with a speed limit and can go that fast without losing any power then it ia a question of the tight tires, weight, and balance. Believe it or not you might have too much power also. I pulled Saturday and had to back out of the throttle to keep from spinning out but it was an extremly hard track.
Friend of ours has a WD with a combine motor in it although he does have a governor on it. He did fair with the standard 16.9X26? tires, The short ones. he went to a set of 13.6X38's and pulls from 3500-5000 with no problem. More HP osn't do alot of good unless you can get it to the ground and if your not bogging out you have enough.
Azhayseed
05-29-2005 21:58:06
Derek,
You have mail!
