AC B Front rim - to be removed
willyboy99
05-26-2005 00:53:46
Hi guys, I recently had delivered a model B with a flat front tire and when I went to remove the tire from the rim I came up against a differet type rim than what I have on my C & WD - no wheel nuts. The rim attached to the hub appears to have what is six nubs on both the front and back of the rim. I cannot figure out how to take the rim off the front frame - no wheel nuts - what am I missing and how do I take the rim off the tractor. Is this rim a real early model.
steve(ill)
05-26-2005 16:05:29
 Re: AC B Front rim - to be removed in reply to willyboy99, 05-26-2005 00:53:46
im no expert, but you are talking about the 1938- 39 versions. I think the original rim was rivited to the hub. you would have to take the center cap off and remove the bearing and take the entire unit off. several months later the rivits were replaced with bolts that can be removed. within a coule years, they went to the 5 boilt pattern you are use to.
