wc shifter
john *.?-!.* cu
05-25-2005 19:31:36
I know this is a basic question for Allis Chalmers people, but I'm an IH guy. a neighbor bought a WC last week that has a small lever on the shifter with a link going into the transmission. what is this for? neither of us can figure it out.
Thanks.
yorkie
05-30-2005 06:16:47
 Re: wc shifter in reply to john *.?-!.* cub owner, 05-25-2005 19:31:36
does any one know about the sherman gear reducton that was an optionon a wc that allowed the original trans to be slowed down for corn picking with a mounted picker on a wc
Dave NE IA
05-27-2005 19:04:49
Alot of the rc, wc, wf, w, etc are worn so it is not needed. A big joke in this part of the world--as we live in some hilly country and those series usually tell you witch way the hill is leaning as the gear shift lever hangs to the bottom on a side hill. The lock out feature does indeed work pretty well if you have a working one, although very rare. Dave NE IA
John *.?-!.* cub owner
05-26-2005 11:51:30
thanks for everyones help
JMS/MN
05-26-2005 10:21:28
The WC, WF, RC had that lever to allow the shift lever to move farther to the right, to let you shift into reverse. Otherwise, the lever moved in a typical 'H' pattern, and made it easier to find the forward gears. My WC's and WF levers are worn and missing the two washers and spring at the bottom of the shaft, so they go to the right with no restriction, but it makes it hard to find 3&4 gears. Just learned the inside story on the shifting tower recently, so will be correcting that.
Sid
05-25-2005 19:36:01
Squeeze the little lever to put the transmission reverse.
Sid
05-25-2005 19:35:53
