D-17 Auxilary valve
dlarso
05-25-2005 08:22:14
Is it possible to add an auxilary hydraulic valve to a D-17 III tractor? If so are they available? Thanks in advance for any information.
JMS/MN
05-25-2005 11:46:02
 Re: D-17 Auxilary valve in reply to dlarso, 05-25-2005 08:22:14
You should have a single-acting remote on the D17. Buy a two-way valve, plug it into the remote, and run a return line from that valve, back to the resevoir. Gives you both single and double acting hydraulics. Extra valve can be for one or several cylinders. If high pressure is an issue, use an appropriate relief valve on the added valve(s).
