d15 hydrolics
travd15
05-23-2005 10:31:51
i am putting a loader on a d15 1963, not sure best way to hook up hydraulics any help would be nice
JMS/MN
05-25-2005 11:51:30
 Re: d15 hydrolics in reply to travd15, 05-23-2005 10:31:51
Factory hydraulic system is fine for a loader with a trip bucket, but for two-way cylinders, like on a hydraulic bucket- you need auxiliary hydraulics. Front mount independent pump is the best system. Check the crankshaft pulley to see if it is drilled/tapped for mounting a shaft for a front pump. D17 II and later were, I'd imagine the D15 might be as well. Easy to hook up a system if you have that.
travd15
05-26-2005 19:33:23
 Re: d15 hydrolics in reply to JMS/MN, 05-25-2005 11:51:30
to jms/mn do you know where to find a pump like that? I assume you are from MN, I live in WI so if there is a local place let me know.
steve(ill)
05-23-2005 15:50:45
the factory hydraulic system is too small and does not hold enough oil for a good loader system. i assume you are using a seperate oil pump mounted on the front of the mtor crank shaft with a coupler? if not, that is what you should be looking at.
travd15
05-24-2005 18:08:37
 Re: d15 hydrolics in reply to steve(ill), 05-23-2005 15:50:45
thanks do you know where to look for something like that?
steve(ill)
05-24-2005 18:54:13
 Re: d15 hydrolics in reply to travd15, 05-24-2005 18:08:37
surpluls center sells pumps and hydraulic vavles if you are trying to build your own. if you dont know where to start you might look on e-bay or other guys and get a unit already setup for a small ALLIS or 8N FORD loader, etc. Biggest problem will be matching a coupling up to the crank shaft and making it fit.
http://www.surpluscenter.com/hydraulic.asp?UID=2004062421044726&catname=hydraulic
