I can Think Of A Third
Dick L
05-23-2005 09:41:27
Which is compression. Sticky valves from setting and bad rings when last run and no oil to block the blow by.
Texas Denny
05-23-2005 12:16:18
 Re: I can Think Of A Third in reply to Dick L, 05-23-2005 09:41:27
Dick, you are, of course, absolutely correct. Since it was turning over good, and it had set only a couple of years, and it is an Allis Chalmers, I figured compression was less likely than gas or spark. I missed this one. I had an Oliver engine that was supposedly freshly rebuilt and set on the floor in a garage. When I tried to start it after installing it, it lacked compression. Pulled the manifold and discovered that mice had used the head for their home - it was full of shlled corn and nesting materials. It had set for 20 years but I guess it could happen faster than that. I doubt that rings set up that fast but then I don't know the conditions of storage. Excellent point!
