7060 Alternator
mips4000
05-23-2005 05:11:22
The alternator light on the console keeps coming on and I don't know why. Any thoughts on other items I should look at?
7060 black belly.
I replaced the alternator with a rebuild. I bought and replaced all 4 batteries? ugh!
I visually inspected the wiring harness. I checked the tension of the belts on the alternator.
When I replaced the alternator, the light went out and was back to normal for about a day. Then it turned back on.
any thoughts? I've been staring at the wiring diagram, but nothing is really jumping out at me.
Thanks.
RJ
05-23-2005 12:15:44
 Re: 7060 Alternator in reply to mips4000, 05-23-2005 05:11:22
I would check to see if alternator is charging and then see if it putting out correct voltage.
I have been having simular problems with my 7045.
My tack will only go up to about 1200 rpm the alternator is charging and i have cleaned the post at the alternator still no luck. I changed over to a delco alternator several years ago, as nobody in my area could work on the orignal.
