Gas engine for a D-17 Series III
DEE SEVENTEEN
05-22-2005 09:18:24
I have been told that certain AC 4 cyl. combine engines will work in a AC D17 Series III wheel tractor! Can any one help with this question?
Also I need a used engine for a AC D-17 Series III tractor!!
Thank yopu
gusthedigger
05-23-2005 10:04:24
 Re: Gas engine for a D-17 Series III in reply to DEE SEVENTEEN, 05-22-2005 09:18:24
I have a D17 motor that I am going to sell.I bought it to put in my WD but I have change my mind. Its all rebuilded ready bolt in. New pistons,rings, sheaves,rebuild starter,exmanfold and water pump.
Tom Hanson
05-25-2005 20:24:36
 Re: Gas engine for a D-17 Series III in reply to gusthedigger, 05-23-2005 10:04:24
I'm having a bit of trouble putting a D-17 in My Wd45, ever do one?
old
05-22-2005 10:32:24
I've heard the same thing and also been told some of the Gleaner combine engines will also work
JMS/MN
05-22-2005 14:26:56
 Re: Gas engine for a D-17 Series III in reply to old, 05-22-2005 10:32:24
Model E Gleaner engine.
Scott L. Schreiner
05-22-2005 16:00:50
 The engine will even fit in a WD 45 in reply to JMS/MN, 05-22-2005 14:26:56
The water pump is diferent and the carb linkage comes from the front. Also the only place to fill it with oil is on top of the valve cover.
JMS/MN
05-22-2005 16:08:28
 Re: The engine will even fit in a WD 45 in reply to Scott L. Schreiner, 05-22-2005 16:00:50
Agreed, and isn't there also an issue of a fuel pump on the E engine- which gets removed because it is not needed with the gravity fuel tank on the tractor?
