WD45 hand clutch
Lee McCormick
05-21-2005 02:39:41
My hand clutch on my WD45 is starting to slip under a heavy load and does not stay engaged if I hit a bump---What is the best way to adjust this clutch and how do I go about it? I've worked on tractors a lot in my lifetime but have never had to do this before---Thank you for any help you can give me
Somerset
05-22-2005 14:20:32
 Re: WD45 hand clutch in reply to Lee McCormick, 05-21-2005 02:39:41
When parking a WD 45 is it best to leave the clutch engaged or disengaged ?
John (C-IL)
05-22-2005 06:23:27
JMS needs to be more precise. The shims are moved from one side of the clutch to the other, you never completely remove the shims. Also, if you have a "kicker" on your hand clutch it will kick the hand clutch out of gear when you hit a bump or an obstruction when plowing.
Brian G. NY
05-22-2005 12:07:15
 Re: WD45 hand clutch in reply to John (C-IL), 05-22-2005 06:23:27
John, I believe you are thinking of the "D" series transmission clutch; the WD & WD-45 are adjusted for wear by removing the shims altogether.
JMS/MN
05-21-2005 14:01:22
Remove the battery and box. Remove the cover underneath. Remove shims from the clutch assembly until the handle 'snaps' like it did years ago.
Brian G. NY
05-23-2005 07:23:25
 Re: WD45 hand clutch in reply to JMS/MN, 05-21-2005 14:01:22
And of course, I didn't mean remove "all" the shims' rather, as JMS says, enuf to put the "snap" back into the clutch. An equal number of shims must be removed from each of the 3 locations.
JMS/MN
05-23-2005 07:31:27
 Re: WD45 hand clutch in reply to Brian G. NY, 05-23-2005 07:23:25
I agree with your idea of removing, rather than moving them. There is no 'other side' on the WD clutch like there is on the 'D' series. That is a hi-lo setup with the clutch in between. Also, when the clutch is worn, the slap of the handle, in rough ground, is enough to snap it over center and release the clutch- as the original poster indicated. The yoke that you see on some tractors, with a linkage between the drawbar and the hand clutch, is designed to be a clutch release when hitting a large obstruction, like a rock.
