WC -cracked block
Govn'r
05-16-2005 20:10:16
On the manifold side of my motor, there is a mending plate that's almost the same size as the whole side of the block. Im rebuilding the motor, and didn't realize what it was until I took it off. One horizontal crack running just above the o-rings on the sleeves that has been welded. And another that looks like an over-sized fish hook above that which hasn't been fixed. Is this a common fix for cracked blocks? Also, tractor is a '42 and the no. on the block by the dipstick is U3019-25. Can anyone tell me if this motor is the same year? Thanks for the help.
Texas Denny
05-16-2005 21:04:10
 Re: WC -cracked block in reply to Govn'r, 05-16-2005 20:10:16
Yes, welding is the common practice for repairing blocks. Some repairs work out. Some do not. If the block doesn't leak anti-freeze, the fix is Ok. If your need is for a working tractor, I wouldn't do anything until it starts to leak (which it may never do). If you want to take it to shows or restore it, you may want to replace the block.
I can't help with the serial number question.
