Need a govenor
Emil
07-07-1999 02:52:58
i am in need of governor and the gear the drives the governor for D14, would a governor off a WD45 work? Is there another governor that would work?
GeneD14
07-07-1999 13:13:57
 Re: need a govenor in reply to Emil , 07-07-1999 02:52:58
Parts catalogs list the same govenor for a D14 and D15. The WD and WD45 used a totally different engine and gov.The D10,D12, and B,C,& CA with a distributor ignition also uses the same govenor as the D14. Walt's tractor parts on the net sells them and Central Tractor sells new and used ones. Good Luck!
