WD-45 Steering Spindles
Phill Snartland
05-16-2005 13:47:21
Maybe someone can help me. I'm restoring a wd-45 with the factor wide front end. This tractor must have had a loader on it at some time in the past, because the steering spindles (and the pivot points on the axle) are very worn. I've repaired the front and rear pivot points, but I'm at a loss to figure out how to get the spindle shaft out of the hub. The old one has to come out because the shaft is very worn where the bushings used to be.
I've tried grinding the weld down until I can see the seam all the way around, and I've drilled out the pin from the side of the hub, but the shaft still won't budge with a 6-ton press.
Any ideas on getting the shaft out of the hub so I can replace the shaft?
Thanks for the help!
Phill S.
JMS/MN
05-17-2005 15:41:54
 Re: WD-45 Steering Spindles in reply to Phill Snartland, 05-16-2005 13:47:21
A few thoughts- a six ton press is likely too light to push out the shaft, especially without oxy-acet heat. Generally, if you can see the entire seam, it should push out with enough pressure and heat. I've done similar several times with the front spindles on a JD 3020. Also- without pushing out the shaft, I wonder if Ickler Machine in STC could build up the shaft and turn it down to new specs. If they can determine a machining center on the shaft, they should be able to do that. I rebuilt a WD45 a few years ago that had bent spindles, not worn like yours are. Never saw a tractor with so much abuse. Welded up the pivots and made new holes.
Phill Snartland
05-23-2005 11:09:29
 Re: WD-45 Steering Spindles in reply to JMS/MN, 05-17-2005 15:41:54
Well, I got the shafts out of the hubs! I had to drill out the center of the shaft where it was inserted into the hub. Once I had drilled about a 1-1/4" hole, the 6 ton press was able to push them out. Worked hard the whole ways, though.
Thanks for the help! Ickler didn't want to try it on their 30-ton press. Suggested Granite City Iron Works, with their 60-ton press.
