WD45 PTO
JackT
05-16-2005 11:33:51
On a WD 45, has anyone ever tried to mount a hydraulic pump where the belt PTO (rt side) normally goes? All I have there is a stamped metal plug. Tried to take it out once to see what was behind it. BIG mistake. Oil everywhere! How is that PTO normally clutched?
Thanks,
Jack
Dave Grubb
05-18-2005 08:31:13
 Re: WD45 PTO in reply to JackT, 05-16-2005 11:33:51
It has been done and there is a picture of the setup on this site somewhere or on the other one. I considered doing it but with drive still related to the foot clutch I couldn't see use.
JMS/MN
05-17-2005 08:45:34
It is not a PTO- it is where the belt pulley fits in. The sleeve of the pulley has a number of tapered holes in it. If the tractor is running you need to lock the foot clutch pedal forward, loosen the setscrew on the top side of the casting, and push the pulley in to engage the gears, then lock it down with the setscrew. With the engine turned off, you don't need to lock the foot clutch forward. Not a handy place to get power for a hydraulic pump. The inertia of the moving pulley makes for slow shifting- have to wait for the pulley to stop in order to shift or engage the PTO. Front mount pump makes a good setup.
Texas Denny
05-16-2005 14:23:36
I've seen this done on WC tractors because they do not have any hydraulics. There are drawbacks to the plan. The chief one is shifting. The pulley has inertia. Once it is spinning, it doesn't want to stop so it cause the gears to stay in motion and makes it harder to shift. If the pump requires a lot of energy, the pump may absorb this inertia and permit shifting to be near normal.
Live hydraulics is still accomplished via the hand clutch. Pushing the foot clutch would stop the belt pulley. This latter issue is the reason that most people go for a front pump ran off the crankshaft - 100% live hydrauics. If you are going to spend the money, it is the way to go.
