WD45 Foot clutch Petal
Willyboy99
05-16-2005 01:22:59
Hi guys, Question; when my tractor - WD45 - was delieved to me, the foot clutch petal would not move - seems to be frozen into place. The previous owner indicated that the clutch was hard to operate when loading the tractor. Does anyone have an explanation and or idea/s as to what I need to do to release the clutch so I can shift into gear and move the tractor - another note - the hand clutch lever seems very difficult to operate also, if that helps.
Bill
JMS/MN
05-16-2005 06:10:48
 Re: WD45 Foot clutch Petal in reply to Willyboy99, 05-16-2005 01:22:59
Both of those clutches are cast iron, pivoting on steel shafts. They my be seized with rust if the tractor was setting for a long time. Remove the pedal and handle, drill and tap for a zerk, and lube them. Operate the linkage without them so you know their is no internal problem.
Tom/Idaho
05-16-2005 04:38:57
It may be pushed to far forward passed the stop on the side of the case. Mine was till I pried it back and re-adjusted the linkage. In my opinion the design is not the best. Tom/Idaho
Willyboy99
05-26-2005 00:20:00
 Re: WD45 Foot clutch Petal in reply to Tom/Idaho, 05-16-2005 04:38:57
thanks guys, your advise led me to the adjustments required to make it work - it is now fine.
