tractor magneto
David Alvarez j
05-15-2005 14:51:53
i have a allis chalmers 1945 model c tractor and it has a magneto ignition system but it sucks!!
is there a kit or a way for me to convert from magneto to points or even to electronic if its possible? Thank You
[email protected]
Glen in TX
05-16-2005 19:05:03
 Re: tractor magneto in reply to David Alvarez j, 05-15-2005 14:51:53
What is really wrong with your mag? Is it a FM J or X or other other brand? I can supply you parts lists, repair instructions if want to fix yourself and parts for those mags in stock or can repair it for you too. I carry OEM parts and a cheaper line of aftermarket parts too. 806-295-3682 [email protected] By the way you can probably get more parts for the magnetos than you can for some of the distributors and if they are worn out then another headache too.
Texas Denny
05-15-2005 20:21:12
I agree with Steve. If the magneto works correctly they are an excellent ignition for tractors. And I believe they go a lot further between maintenance. I'd pay to fix it rather than switching to a distributor. I have a mag in my C.
steve(ill)
05-15-2005 15:27:01
the later tractors like the CA used a distributor and coil. you can look around and find one of those and install if thats what you want. what is wrong with the mag?? i have two model B tractos with mag. i have electric starter, good timing, and new plugs. i hit thte starter, motor turns over 1 revolution and tractor is running. a good mag is a great ignition system. you can have them rebuilt by STEVE at B&B probalby same price as a distributor.
